Saltar al contenido principal
Samsung 27E510C NAV Button Replacement
Qué necesitas
  1. Samsung 27E510C  NAV Button Replacement, Back Panel: paso 1, imagen 1 de 3 Samsung 27E510C  NAV Button Replacement, Back Panel: paso 1, imagen 2 de 3 Samsung 27E510C  NAV Button Replacement, Back Panel: paso 1, imagen 3 de 3
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C  NAV Button Replacement: paso 2, imagen 1 de 2 Samsung 27E510C  NAV Button Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Heavy-Duty Spudger
    Comprar
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C  NAV Button Replacement, Rear navigation button: paso 3, imagen 1 de 1
    • Carefully remove the tape holding down the connector wire.
    • You will need to re-attach the tape upon reassembly.
  4. Samsung 27E510C  NAV Button Replacement: paso 4, imagen 1 de 1
    • Disconnect the navigation button from the motherboard by holding down the thumb tab and pulling its connector out.
  5. Samsung 27E510C  NAV Button Replacement: paso 5, imagen 1 de 2 Samsung 27E510C  NAV Button Replacement: paso 5, imagen 2 de 2
    • Remove the navigation buttons connector wire from the monitors body tab.
  6. Samsung 27E510C  NAV Button Replacement: paso 6, imagen 1 de 1
    • With one thumb, hold down the tab on the bottom of the navigation buttons base.
    • While holding the tab down, lift the base of the navigation button with your other hand.
  7. Samsung 27E510C  NAV Button Replacement: paso 7, imagen 1 de 3 Samsung 27E510C  NAV Button Replacement: paso 7, imagen 2 de 3 Samsung 27E510C  NAV Button Replacement: paso 7, imagen 3 de 3
    • Remove the connector wire from the defective navigation button by first gripping its connectors thumb tab.
    • While gripping the thumb tab, pull the connector from the base of the navigation button.
    • You can save the connector wire since it may not be defective.
Conclusión
giggythore
Miembro Desde 10/14/17
366 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S9-G1, Banghart Fall 2017 Miembro de Cal Poly, Team S9-G1, Banghart Fall 2017
CPSU-BANGHART-F17S9G1
6 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 20
Todo El Tiempo: 495
