Saltar al contenido principal
Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement
Qué necesitas
  1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: paso 1, imagen 1 de 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: paso 1, imagen 2 de 2
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: paso 2, imagen 1 de 3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: paso 2, imagen 2 de 3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: paso 2, imagen 3 de 3
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: paso 3, imagen 1 de 3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: paso 3, imagen 2 de 3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: paso 3, imagen 3 de 3
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: paso 4, imagen 1 de 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: paso 4, imagen 2 de 2
    • Remove the green protective tape from the three ZIF connectors on the motherboard.
    • Pull the ribbon cables out of their sockets.
  5. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: paso 5, imagen 1 de 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: paso 5, imagen 2 de 2
    • Remove the six 4mm Phillips #000 screws from the motherboard.
    • Remove the motherboard.
  6. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: paso 6, imagen 1 de 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: paso 6, imagen 2 de 2
    • Insert a plastic opening tool between the screen and bezel.
    • Slide the plastic opening tool around the perimeter while applying a prying motion.
    • Remove the screen from the display.
    • Applying heat may be needed to loosed the glue.
  7. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: paso 7, imagen 1 de 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: paso 7, imagen 2 de 2
    • Locate the Home button on the front of the panel and carefully lift the gold ribbon surrounding it from RIGHT to LEFT.
  8. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: paso 8, imagen 1 de 1
    • Using your Phillips #000 screwdriver Remove the two 4mm Phillips #000 screws from the home button.
  9. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: paso 9, imagen 1 de 1
    • Remove the home button by sliding it to the left or right while pulling up.
Conclusión
Una persona más ha completado esta guía.
Guneet Bawa
Miembro Desde 04/12/18
688 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team S1-G5, Liner Spring 2018 Miembro de UW Tacoma, Team S1-G5, Liner Spring 2018
UWT-LINER-S18S1G5
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 2,012
