Saltar al contenido principal
Saeco Royal Support valve seals Replacement
Qué necesitas
  1. Saeco Royal Support valve seals Replacement, Preparing: paso 1, imagen 1 de 1
    • Unplug!
    • Remove all attachments like water tank, brewing unit etc.
    • The pictures show a Royal Cappucino One Touch HD8930, but the opening procedure is similar to all models.
  2. Saeco Royal Support valve seals Replacement, Top: paso 2, imagen 1 de 2 Saeco Royal Support valve seals Replacement, Top: paso 2, imagen 2 de 2
    • The coffeebean supply is fixed with two screws. Unscrew them and lift it off.
    • There is a black rubber lid under the bean hopper that you can easily lift off, leaving a large opening.
    • The adjuster of the grinder has to be solved. Mark the position or just take a picture. This type is fixed with a screw, others are only sticked together.
  3. Saeco Royal Support valve seals Replacement, Rear side: paso 3, imagen 1 de 1
    • There are two screws to be turned out.
  4. Saeco Royal Support valve seals Replacement, Front: paso 4, imagen 1 de 3 Saeco Royal Support valve seals Replacement, Front: paso 4, imagen 2 de 3 Saeco Royal Support valve seals Replacement, Front: paso 4, imagen 3 de 3
    • The screws are situated on the underneath of the cover. This type is held by four screws.
  5. Saeco Royal Support valve seals Replacement, Lift cover off: paso 5, imagen 1 de 2 Saeco Royal Support valve seals Replacement, Lift cover off: paso 5, imagen 2 de 2
    • Now the cover can be raised: first grip on left and right rear side and lift about 10 cm (4 in). Sometimes the cover jams a little bit.
    • Solve the hoses which lead to the water tank. Perhaps you have to pull out some contacts, (e.g. the yellow-green protection lead), don´t forget to put them on again later.
    • The cover can be drawn aslant towards the front, sliding it over the hot water pipe.
    • Most repairs can be done with the cover being laid up partially , it must not be completely removed.
  6. Saeco Royal Support valve seals Replacement, To open: paso 6, imagen 1 de 1
    • On some models, the support valve is bolted to the heater. There are these instructions.
  7. Saeco Royal Support valve seals Replacement, Release support valve: paso 7, imagen 1 de 1
    • The support valve is visible when the brew group has been removed. It represents the connection between the hot pressurized water and the brewing group.
    • Two big screws hold the valve, here 6mm Allen screws. To solve.
  8. Saeco Royal Support valve seals Replacement, Replacing the seals: paso 8, imagen 1 de 1
    • Danger. The small sliding piece in the valve is sensitive.
    • Careful cleaning is very beneficial to the aroma.
    • The valve is single in this model. Here two seals are exchanged. For other models, it is bolted directly to the heater. In this case, remove the heater and valve and unscrew the valve. You then have to replace three seals.
  9. Saeco Royal Support valve seals Replacement: paso 9, imagen 1 de 1
    • Unscrew the valve piece with a wrench SW 13.
    • Check if everything is smooth. Clean all parts well. Careful, they are sensitive.
    • The valve spring.
    • The valve stamp. Check if the gasket on the valve seat is still good. Change it if necessary.
    • The sliding piece.
    • Support seal on the thermoblock. Medium size.
    • Support gasket above. The biggest of the three.
    • Support gasket below. The smallest.
Conclusión
Repeat the steps in order to reassemble your device.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
de en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
VauWeh
Miembro Desde 10/19/15
201,502 Reputación
246 Guías creadas
Equipo
Repair is War on Entropy Miembro de Repair is War on Entropy
Community
24 Miembros
1,096 Guías creadas
Un comentario
Wow! I dare anybody to follow these instruction for a successful repair. Terrible sequence and explanation. Just look at the pictures (they are good and clear) and try to figure out the rest.
Axxam Enni - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 81
Todo El Tiempo: 7,200
