Saltar al contenido principal
Saeco Incanto SBS Piston Head Seals / O-rings Replacement
Qué necesitas
  1. Saeco Incanto SBS Piston Head Seals / O-rings Replacement, Piston Head Seals / O-rings: paso 1, imagen 1 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement, Piston Head Seals / O-rings: paso 1, imagen 2 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement, Piston Head Seals / O-rings: paso 1, imagen 3 de 3
    • I show you the O-rings in the top piston of the brewgroup. I don't write much, because my english is bad, but the photos speak for themselves. Good luck
    • Two screws, PZ 1
    • Careful, there is a spring.
  2. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 2, imagen 1 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 2, imagen 2 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 2, imagen 3 de 3
    • Spring, O-ring and a GLASBALL.
  3. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 3, imagen 1 de 1
    • Ja
  4. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 4, imagen 1 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 4, imagen 2 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 4, imagen 3 de 3
    • Remove the piston. More information in my guide " Disassembling & Cleaning the Brewgroup" here.
  5. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 5, imagen 1 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 5, imagen 2 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 5, imagen 3 de 3
    • Screw PZ 1
    • Counterrotate turning the screw.
    • Then pull that thing and you find another seal
  6. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 6, imagen 1 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 6, imagen 2 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 6, imagen 3 de 3
    • Details
  7. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 7, imagen 1 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 7, imagen 2 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 7, imagen 3 de 3
    • Tools for cleaning, ja toothbrush
  8. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 8, imagen 1 de 2 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 8, imagen 2 de 2
    • There are two types of O-rings. For this type of piston you need the smaller.
  9. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 9, imagen 1 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 9, imagen 2 de 3 Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 9, imagen 3 de 3
    • Grease it a liitle.
    • Just put it back, no problem.
  10. Saeco Incanto SBS Piston Head Seals / O-rings Replacement: paso 10, imagen 1 de 1
    • ...and then I found a crack in my piston. That can not be repaired. So I had to buy a new piston.
Conclusión
4 personas más completaron esta guía.
Schwarzstein
Miembro Desde 07/15/13
2,813 Reputación
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 25
Todo El Tiempo: 3,600
