Saltar al contenido principal
SR405QM Battery Replacement
Qué necesitas
  1. SR405QM Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Gently place the instrument upside-down on a soft surface.
    • Locate the battery cavity cap and screws.
  2. SR405QM Battery Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #2 head screwdriver to unscrew both screws. Two #1 1mm long screws.
  3. SR405QM Battery Replacement: paso 3, imagen 1 de 2 SR405QM Battery Replacement: paso 3, imagen 2 de 2
    • Remove the cap by lifting upwards to reveal the battery.
  4. SR405QM Battery Replacement: paso 4, imagen 1 de 3 SR405QM Battery Replacement: paso 4, imagen 2 de 3 SR405QM Battery Replacement: paso 4, imagen 3 de 3
    • Gently lift the battery from the cavity.
    • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
Conclusión
To reassemble your device, follow these instructions in reverse order with a fresh battery.
2 personas más completaron esta guía.
Chris Pittner
Miembro Desde 01/11/13
220 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 5-18, Forte Winter 2013 Miembro de Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 1,180
