Introducción
As speakers get older, and as they experience more wear from being played at high volume, they can eventually blow out.
Instead of throwing away your whole speaker system, it is actually very easy to replace an individual, blown out speaker. Replacement speakers are also very easy to find online, or salvage from other devices.
Qué necesitas
Lift up the handle to reveal the screws.
Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
This guide will be for the two speakers seen on the left and right of the image.
