Saltar al contenido principal
SONY ZS-BTG900 Remote Motherboard Replacement
Qué necesitas
  1. SONY ZS-BTG900 Remote Motherboard Replacement, Remote Motherboard: paso 1, imagen 1 de 2 SONY ZS-BTG900 Remote Motherboard Replacement, Remote Motherboard: paso 1, imagen 2 de 2
    • Flip the remote and remove the backing.
  2. SONY ZS-BTG900 Remote Motherboard Replacement: paso 2, imagen 1 de 2 SONY ZS-BTG900 Remote Motherboard Replacement: paso 2, imagen 2 de 2
    • Locate the screw behind the battery pack.
    • Use a Phillips size 1 screwdriver to remove the 5/16in screw located inside the battery port.
  3. SONY ZS-BTG900 Remote Motherboard Replacement: paso 3, imagen 1 de 2 SONY ZS-BTG900 Remote Motherboard Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool along the seam on the side of the remote until you hear a click. This means that the plastic tabs holding the remote together are coming loose.
    • Do this until the top half of the remote comes loose.
  4. SONY ZS-BTG900 Remote Motherboard Replacement: paso 4, imagen 1 de 2 SONY ZS-BTG900 Remote Motherboard Replacement: paso 4, imagen 2 de 2
    • Carefully remove the top to reveal the button covers and the remote control board.
  5. SONY ZS-BTG900 Remote Motherboard Replacement: paso 5, imagen 1 de 2 SONY ZS-BTG900 Remote Motherboard Replacement: paso 5, imagen 2 de 2
    • Lift the chip out of the plastic casing to replace it.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 436
