Saltar al contenido principal
SOMNOcomfort and SOMNObalance Ventilator Filter Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
  1. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement, Filter: paso 1, imagen 1 de 1
    • Locate the Filter Compartment on the back of the ventilator.
  2. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement: paso 2, imagen 1 de 1
    • Push the compartment cover (22) up (from the bottom)
  3. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement: paso 3, imagen 1 de 1
    • Remove the coarse dust filter(68)
  4. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement: paso 4, imagen 1 de 1
    • Remove the fine dust filter(67)
    • Replace the filters and close the cover on the rear of the unit.
  5. SOMNOcomfort and SOMNObalance Ventilator Filter Replacement: paso 6, imagen 1 de 1
    • Reset the filter change indicator by pressing and holding the on/off switch(19) until the filter change indicator goes blank.
    • If the fine filter was changed due to soiling before 250 operating hours, the hours meter must be reset to zero. Proceed as follows:
    • When switching the unit on, press and hold the on/off switch 19. The filter change indicator will come on after about three seconds before going off again after another three seconds. Release the on and off switch.
Conclusión
Diya Jamwal
Miembro Desde 11/07/18
553 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S1-G3, Zimmerman Spring 2020 Miembro de Cal Poly, Team S1-G3, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G3
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 121
