Saltar al contenido principal
SM Santa Marin hand watch Battery Replacement
Qué necesitas
  1. SM Santa Marin hand watch Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Take apart the steel strap for the watch by using the round head (SIM) screwdriver. Then pull out the screw.
  2. SM Santa Marin hand watch Battery Replacement: paso 2, imagen 1 de 1
    • Remove four screws from the back cover using the Y000 screwdriver .
  3. SM Santa Marin hand watch Battery Replacement: paso 3, imagen 1 de 1
    • Remove the back cover of the watch using the opening tool.
  4. SM Santa Marin hand watch Battery Replacement: paso 4, imagen 1 de 1
    • Remove the plastic gasket from on top of the battery using the opening tool.
  5. SM Santa Marin hand watch Battery Replacement: paso 5, imagen 1 de 1
    • Loosen the battery bracket from the watch by placing the 1mm flathead screwdriver under and lifting carefully.
  6. SM Santa Marin hand watch Battery Replacement: paso 6, imagen 1 de 2 SM Santa Marin hand watch Battery Replacement: paso 6, imagen 2 de 2
    • Take the old battery out using the plastic opening tool or spudger.
Conclusión
Un comentario
It's amazing and also work as a machenic for me
Talha - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 16
Todo El Tiempo: 899
