Saltar al contenido principal
SHARP EL-W53XG WriteView Battery Replacement
Qué necesitas
  1. SHARP EL-W53XG WriteView  Battery Replacement, Battery: paso 1, imagen 1 de 2 SHARP EL-W53XG WriteView  Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Turn off the calculator by pressing both the [2NDF ] and [ON] buttons at the same time.
  2. SHARP EL-W53XG WriteView  Battery Replacement: paso 2, imagen 1 de 1
    • Flip the calculator so that the battery cover is facing you, and it will be easy to remove.
  3. SHARP EL-W53XG WriteView  Battery Replacement: paso 3, imagen 1 de 2 SHARP EL-W53XG WriteView  Battery Replacement: paso 3, imagen 2 de 2
    • Remove the two screws securing the battery cover with the Tri-point #000 screwdriver.
    • Remove the battery cover.
    • Make sure not to remove the other screws on the calculator, just the two screws on the battery cover.
  4. SHARP EL-W53XG WriteView  Battery Replacement: paso 4, imagen 1 de 2 SHARP EL-W53XG WriteView  Battery Replacement: paso 4, imagen 2 de 2
    • Remove the worn-out LR44 battery inside using a spudger.
  5. SHARP EL-W53XG WriteView  Battery Replacement: paso 5, imagen 1 de 1
    • Gently insert the new LR44 battery in the empty battery slot.
  6. SHARP EL-W53XG WriteView  Battery Replacement: paso 6, imagen 1 de 1
    • Place and screw the battery cover on using the Tri-point #000 screwdriver.
    • Tightly screw the battery cover to prevent losing screws.
Conclusión
Faduma Hagi
Miembro Desde 09/14/21
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 34
Todo El Tiempo: 1,519
