Saltar al contenido principal
SHARK WANDVAC WV205 Battery Replacement
Qué necesitas
  1. SHARK WANDVAC WV205 Battery Replacement, Battery: paso 1, imagen 1 de 2 SHARK WANDVAC WV205 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Push the sliding button to open the dirt capsule to empty it out.
    • Ensure to do this over a garbage can/bag to prevent a mess.
  2. SHARK WANDVAC WV205 Battery Replacement: paso 2, imagen 1 de 2 SHARK WANDVAC WV205 Battery Replacement: paso 2, imagen 2 de 2
    • Using a coin or other thin item, such as a guitar pick, push the cap at the end of the vacuum out. Switch between sides to make it come out evenly.
    • This could take more time than expected.
  3. SHARK WANDVAC WV205 Battery Replacement: paso 3, imagen 1 de 2 SHARK WANDVAC WV205 Battery Replacement: paso 3, imagen 2 de 2
    • Once the battery is popped out, carefully pull it out.
  4. SHARK WANDVAC WV205 Battery Replacement: paso 4, imagen 1 de 2 SHARK WANDVAC WV205 Battery Replacement: paso 4, imagen 2 de 2
    • To properly store and then dispose of the battery put it in a clear plastic bag.
  5. SHARK WANDVAC WV205 Battery Replacement: paso 5, imagen 1 de 2 SHARK WANDVAC WV205 Battery Replacement: paso 5, imagen 2 de 2
    • Slot your replacement battery where the old one was.
    • Once inside, push hard on the end until you hear a click.
  6. SHARK WANDVAC WV205 Battery Replacement: paso 6, imagen 1 de 1
    • Test the vacuum to ensure the replacement succeeded.
Conclusión
To properly dispose of the old battery consult your cities policies on lithium ion battery disposal.
Nicolaas
Miembro Desde 01/16/24
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 38
Todo El Tiempo: 129
