Saltar al contenido principal
SGH-A117 keypad replacement
Qué necesitas
  1. SGH-A117 keypad replacement, Battery: paso 1, imagen 1 de 1
    • Remove the battery by pressing the battery lock down and slide the battery cover away.
  2. SGH-A117 keypad replacement: paso 2, imagen 1 de 1
    • Lift the bottom of the battery and then move it up and away.
  3. SGH-A117 keypad replacement, Motherboard: paso 3, imagen 1 de 1
    • Locate the 4 screws holes on the phone and remove them with the #000 Philips Head screwdriver. (See red circles)
  4. SGH-A117 keypad replacement: paso 4, imagen 1 de 1
    • Using the plastic opening tool, gently pry open the back piece of the phone.
    • Make sure to do this very carefully, as the back part of the phone is very thin and fragile.
  5. SGH-A117 keypad replacement: paso 5, imagen 1 de 1
    • Use the metal prying tool to gently flick up the rectangular connector. (Because this device is on the smaller side, the rectangular connector may only need a simple flick with the prying tool)
    • Simply flick the rectangular connector up from its socket. (Highlighted by the red square)
  6. SGH-A117 keypad replacement: paso 6, imagen 1 de 1
    • Use the plastic opening tool to gently pry up the motherboard.
    • You may need to pry the motherboard up from several angles in order to remove it.
  7. SGH-A117 keypad replacement, Keypad: paso 7, imagen 1 de 1
    • After the connector has been removed you will gently pull off the mother board, which will reveal the rubber keypad.
  8. SGH-A117 keypad replacement: paso 8, imagen 1 de 1
    • Replace the faulty keypad, and reassemble the phone.
Conclusión
2 personas más completaron esta guía.
Stephanie Isaac
Miembro Desde 09/11/15
431 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 222
