Saltar al contenido principal
SG 552-1 Commando Barrel Replacement
Qué necesitas
  1. SG 552-1 Commando Barrel Replacement, Barrel: paso 1, imagen 1 de 2 SG 552-1 Commando Barrel Replacement, Barrel: paso 1, imagen 2 de 2
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Pull the hand guard off.
  2. SG 552-1 Commando Barrel Replacement: paso 2, imagen 1 de 2 SG 552-1 Commando Barrel Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun. There should be four total.
  3. SG 552-1 Commando Barrel Replacement: paso 3, imagen 1 de 2 SG 552-1 Commando Barrel Replacement: paso 3, imagen 2 de 2
    • Locate the button to fold over the folding stock and fold over the folding stock.
    • Using a Phillips #1 screwdriver, remove the 20mm screw located behind the folding stock.
  4. SG 552-1 Commando Barrel Replacement: paso 4, imagen 1 de 2 SG 552-1 Commando Barrel Replacement: paso 4, imagen 2 de 2
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw located directly underneath the cocking lever.
    • Remove the 8mm screw beside the one you just removed.
  5. SG 552-1 Commando Barrel Replacement: paso 5, imagen 1 de 2 SG 552-1 Commando Barrel Replacement: paso 5, imagen 2 de 2
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
  6. SG 552-1 Commando Barrel Replacement: paso 6, imagen 1 de 3 SG 552-1 Commando Barrel Replacement: paso 6, imagen 2 de 3 SG 552-1 Commando Barrel Replacement: paso 6, imagen 3 de 3
    • Pull the barrel out from the cover.
    • Remove the pieces at the end of the barrel.
  7. SG 552-1 Commando Barrel Replacement: paso 7, imagen 1 de 2 SG 552-1 Commando Barrel Replacement: paso 7, imagen 2 de 2
    • Remove the remaining pieces of on the ends of the barrel.
Conclusión
Laura Schulz
Miembro Desde 10/05/12
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 18-41, Regan Fall 2012 Miembro de Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 1,673
