Saltar al contenido principal
SEGA Genesis Flashback Controller Buttons Replacement
Qué necesitas
  1. SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: paso 1, imagen 1 de 3 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: paso 1, imagen 2 de 3 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: paso 1, imagen 3 de 3
    • Hold the controller with the bottom plate facing up, and gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
    • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
    • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
  2. SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: paso 2, imagen 1 de 2 SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: paso 2, imagen 2 de 2
    • CAUTION: Pull gently on the rubber membranes to avoid tearing .
    • Use two fingers to remove each rubber membrane that rests on top of the buttons.
  3. SEGA Genesis Flashback Controller Buttons Replacement: paso 3, imagen 1 de 1
    • Pop the button out from the front side of the controller.
    • Pull the button out from the backside using the other hand.
    • All removable buttons can only be placed in their respective holes due to unique groove patterns on the buttons. Keep in mind where each button belongs to make re-assembly easier.
    • All buttons can be removed except for the D-Pad.
  4. SEGA Genesis Flashback Controller Buttons Replacement: paso 4, imagen 1 de 1
    • Repeat Step 3 for the remaining buttons.
    • The button should pop out seamlessly and placed to the side.
    • Repeat the prior steps in order to remove all the buttons. Set them aside in an order you will remember to where they belong.
Conclusión
After completing step 4 you will need to re-assemble your controller. Do this by starting from step 2 and work backwards.
Una persona más ha completado esta guía.
Viet Nguyen
Miembro Desde 04/17/18
220 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S24-G12, Maness Spring 2018 Miembro de Cal Poly, Team S24-G12, Maness Spring 2018
CPSU-MANESS-S18S24G12
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 26
Todo El Tiempo: 1,624
