Saltar al contenido principal
Ryobi RY42102 Leaf Blower Fan Replacement
Qué necesitas
  1. Ryobi RY42102 Leaf Blower Fan Replacement, Fan: paso 1, imagen 1 de 3 Ryobi RY42102 Leaf Blower Fan Replacement, Fan: paso 1, imagen 2 de 3 Ryobi RY42102 Leaf Blower Fan Replacement, Fan: paso 1, imagen 3 de 3
    • Lay the blower on its side so that most of the screw heads are facing up. Identify all 9 screw locations.
    • One screw is located under the sticker with the number 8 on it.
    • Another screw is located on the opposite side.
  2. Ryobi RY42102 Leaf Blower Fan Replacement: paso 2, imagen 1 de 1
    • Using a T15 torx drive(star-head), carefully remove each of the 9 screws and set aside in a secure location. All 9 screws are 10 mm long.
  3. Ryobi RY42102 Leaf Blower Fan Replacement: paso 3, imagen 1 de 2 Ryobi RY42102 Leaf Blower Fan Replacement: paso 3, imagen 2 de 2
    • After all 9 screws have been removed, seperate the handle housing the on/off switch.
  4. Ryobi RY42102 Leaf Blower Fan Replacement: paso 4, imagen 1 de 1
    • Once the handle has been separated, the blower shaft with detach from the motor housing. Slide the blower shaft out of the motor housing and set aside.
  5. Ryobi RY42102 Leaf Blower Fan Replacement: paso 5, imagen 1 de 1
    • Once the blower shaft is detached, the fan will be visible. Use a ratchet with a 1/2" socket to remove the 1/2" nut securing the fan to the motor. This nut is reverse thread so turning it clockwise will loosen it. The fan will also need to be secured so that it does not spin as the nut is being loosened.
  6. Ryobi RY42102 Leaf Blower Fan Replacement: paso 6, imagen 1 de 3 Ryobi RY42102 Leaf Blower Fan Replacement: paso 6, imagen 2 de 3 Ryobi RY42102 Leaf Blower Fan Replacement: paso 6, imagen 3 de 3
    • Remove new fan from package and install as shown. Screw the nut back on to secure the fan. Remember the nut is reverse thread, so turning it counter clockwise will tighten it. The fan will also need to be secured while the nut is being tightened.
  7. Ryobi RY42102 Leaf Blower Fan Replacement: paso 7, imagen 1 de 3 Ryobi RY42102 Leaf Blower Fan Replacement: paso 7, imagen 2 de 3 Ryobi RY42102 Leaf Blower Fan Replacement: paso 7, imagen 3 de 3
    • Slide blower shaft back into motor housing, close handle back around blower shaft and motor housing, and screw all 9 screws back into their location.
Conclusión
Take leaf blower outside before operating to evaluate repair success.
2 personas más completaron esta guía.
7 comentarios
Thank you!!! Exactly what I needed!
EK1914 - Contestar
My blower is not like yours. Mine like a fun has corn shaped. How to replace this fun. I need your help.
Jerome Hatano - Contestar
Thanks for the tip, mine is a cordless 18 v and it's slightly more difficult then shown but not impossible!!
It's all plastic and kinda worried about breaking something. I've had mine like for almost 2 yrs. I was using it and barely bumped the wall and the blade just exploded….Really crazy weird.
Thanks for the help.
Clint Porter - Contestar
Cannot find the correct part on the internet anywhere. Mine is orange and flat on the back side; not coned & green as shown in your tutorial.
Jan Dru Basehart
Jan D Basehart - Contestar
Jan I believe mine was orange originally as well. I would try to contact their parts department to ensure it will work before ordering though.
Justin Hannah - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 20
Ultimos 30 días: 122
Todo El Tiempo: 13,275
