Introducción
If your Ryobi RS290G is having power trouble this guide will show you how to successfully replace the power switch.
Qué necesitas
Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
Slide the power switch out of the housing assembly by carefully gripping the power switch and sliding upward from the base.
To reassemble your device, follow these instructions in reverse order. After reassembling, perform an operational check before using.
