Saltar al contenido principal
Ryobi RS290G Power Switch Replacement
Qué necesitas
  1. Ryobi RS290G Power Switch Replacement, Top Cap: paso 1, imagen 1 de 1
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
  2. Ryobi RS290G Power Switch Replacement: paso 2, imagen 1 de 1
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
  3. Ryobi RS290G Power Switch Replacement: paso 3, imagen 1 de 1
    • Remove the top cap.
  4. Ryobi RS290G Power Switch Replacement, Switch Trigger: paso 4, imagen 1 de 1
    • Remove the switch trigger.
  5. Ryobi RS290G Power Switch Replacement, Power Switch: paso 5, imagen 1 de 2 Ryobi RS290G Power Switch Replacement, Power Switch: paso 5, imagen 2 de 2
    • Slide the power switch out of the housing assembly by carefully gripping the power switch and sliding upward from the base.
  6. Ryobi RS290G Power Switch Replacement: paso 6, imagen 1 de 3 Ryobi RS290G Power Switch Replacement: paso 6, imagen 2 de 3 Ryobi RS290G Power Switch Replacement: paso 6, imagen 3 de 3
    • Slide the red and black leads from the power switch using a spudger.
Conclusión
To reassemble your device, follow these instructions in reverse order. After reassembling, perform an operational check before using.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 856
