Saltar al contenido principal
Ryobi RS290G Brush Assembly Replacement
Qué necesitas
  1. Ryobi RS290G Brush Assembly Replacement, Top Cap: paso 1, imagen 1 de 1
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
  2. Ryobi RS290G Brush Assembly Replacement: paso 2, imagen 1 de 1
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
  3. Ryobi RS290G Brush Assembly Replacement: paso 3, imagen 1 de 1
    • Remove the top cap.
  4. Ryobi RS290G Brush Assembly Replacement, Switch Trigger: paso 4, imagen 1 de 1
    • Remove the switch trigger.
  5. Ryobi RS290G Brush Assembly Replacement, Brush Assembly: paso 5, imagen 1 de 2 Ryobi RS290G Brush Assembly Replacement, Brush Assembly: paso 5, imagen 2 de 2
    • Slide the power switch out of the housing assembly by carefully gripping the power switch and slide upward from the base.
  6. Ryobi RS290G Brush Assembly Replacement: paso 6, imagen 1 de 1
    • Remove the two 16mm Phillips #2 screws from the inner housing assembly.
  7. Ryobi RS290G Brush Assembly Replacement: paso 7, imagen 1 de 1
    • Remove the two 14mm Phillips #2 screws from the cord clamp.
  8. Ryobi RS290G Brush Assembly Replacement: paso 8, imagen 1 de 1
    • Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
  9. Ryobi RS290G Brush Assembly Replacement: paso 9, imagen 1 de 2 Ryobi RS290G Brush Assembly Replacement: paso 9, imagen 2 de 2
    • Slide out both brush assemblies from the inner housing assembly.
  10. Ryobi RS290G Brush Assembly Replacement: paso 10, imagen 1 de 1
    • Slide off the disconnect terminal for the brush assembly (white lead).
  11. Ryobi RS290G Brush Assembly Replacement: paso 11, imagen 1 de 1
    • Slide off the disconnect terminal for the brush assembly (black lead).
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 728
