Saltar al contenido principal
Ryobi RS290G Bearing Cap Assembly Replacement
Qué necesitas
  1. Ryobi RS290G Bearing Cap Assembly Replacement, Bearing Cap Assembly: paso 1, imagen 1 de 2 Ryobi RS290G Bearing Cap Assembly Replacement, Bearing Cap Assembly: paso 1, imagen 2 de 2
    • Using a TR20 Torx security screwdriver, remove the four 6mm screws.
    • Make sure to hold the backing pad firmly to prevent spinning.
  2. Ryobi RS290G Bearing Cap Assembly Replacement: paso 2, imagen 1 de 1
    • After removing the backing pad, carefully pull on the rubber brake to remove it from the housing assembly.
  3. Ryobi RS290G Bearing Cap Assembly Replacement: paso 3, imagen 1 de 1
    • Using a TR 20 Torx security screwdriver, remove the single 3mm screw in the center of the bearing cap assembly.
    • Make sure to use pliers or another tool to prevent the fan from spinning, and use a torque wrench or torque screwdriver as the screw is secured with Loctite (a compound to prevent it from loosening).
  4. Ryobi RS290G Bearing Cap Assembly Replacement: paso 4, imagen 1 de 1
    • Remove the bearing cap.
    • You may keep the spring washer and washer for reuse if they are not worn/damaged.
Conclusión
To reassemble your device, follow these instructions in reverse order. Make sure to tighten down properly to avoid loose or traction pad issues.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 519
