Saltar al contenido principal
Ryobi RJ1861V Saw Bar Assembly Replacement
Qué necesitas
  1. Ryobi RJ1861V Saw Bar Assembly Replacement, Saw Bar Assembly: paso 1, imagen 1 de 1
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Saw Bar Assembly Replacement: paso 2, imagen 1 de 2 Ryobi RJ1861V Saw Bar Assembly Replacement: paso 2, imagen 2 de 2
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Saw Bar Assembly Replacement: paso 3, imagen 1 de 1
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Saw Bar Assembly Replacement: paso 4, imagen 1 de 1
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Saw Bar Assembly Replacement: paso 5, imagen 1 de 1
    • Remove the backside panel.
  6. Ryobi RJ1861V Saw Bar Assembly Replacement: paso 6, imagen 1 de 1
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Saw Bar Assembly Replacement: paso 7, imagen 1 de 1
    • Lift the assembly bar up and out of the chassis.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 35
Todo El Tiempo: 886
