Saltar al contenido principal
Ryobi RJ1861V Motor Replacement
Qué necesitas
  1. Ryobi RJ1861V Motor Replacement, Saw Bar Assembly: paso 1, imagen 1 de 1
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Motor Replacement: paso 2, imagen 1 de 2 Ryobi RJ1861V Motor Replacement: paso 2, imagen 2 de 2
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Motor Replacement: paso 3, imagen 1 de 1
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Motor Replacement: paso 4, imagen 1 de 1
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Motor Replacement: paso 5, imagen 1 de 1
    • Remove the backside panel.
  6. Ryobi RJ1861V Motor Replacement: paso 6, imagen 1 de 1
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Motor Replacement: paso 7, imagen 1 de 1
    • Lift the assembly bar up and out of the chassis.
  8. Ryobi RJ1861V Motor Replacement, Assembly Bar Bearing: paso 8, imagen 1 de 1
    • Begin with the top of the device facing up.
  9. Ryobi RJ1861V Motor Replacement: paso 9, imagen 1 de 1
    • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
  10. Ryobi RJ1861V Motor Replacement: paso 10, imagen 1 de 1
    • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
  11. Ryobi RJ1861V Motor Replacement, Motor: paso 11, imagen 1 de 1
    • The motor is divided into two sections, one attached to the gear case and one attached to the handle.
    • This arrow indicates the section attached to the gear case.
    • This arrow indicates the section attached to the handle.
  12. Ryobi RJ1861V Motor Replacement: paso 12, imagen 1 de 3 Ryobi RJ1861V Motor Replacement: paso 12, imagen 2 de 3 Ryobi RJ1861V Motor Replacement: paso 12, imagen 3 de 3
    • Use a Torx T5 screwdriver to remove the four screws attaching the motor to the gear case.
  13. Ryobi RJ1861V Motor Replacement: paso 13, imagen 1 de 1
    • Use a Torx T5 screwdriver to remove the two screws inside the motor housing of the handle.
  14. Ryobi RJ1861V Motor Replacement: paso 14, imagen 1 de 2 Ryobi RJ1861V Motor Replacement: paso 14, imagen 2 de 2
    • Remove the four screws on the back of the housing with a Torx T5 screwdriver.
    • Flip the housing over and pull the motor up and out of the housing.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 296
