Saltar al contenido principal
Ryobi P516 Top Case Replacement
Qué necesitas
  1. Ryobi P516 Top Case Replacement, Top Case: paso 1, imagen 1 de 2 Ryobi P516 Top Case Replacement, Top Case: paso 1, imagen 2 de 2
    • Using the 5mm hex key included at the base of the saw, loosen the set screw at the front of the saw.
    • The front guard will now slide out from the front of the saw.
  2. Ryobi P516 Top Case Replacement: paso 2, imagen 1 de 3 Ryobi P516 Top Case Replacement: paso 2, imagen 2 de 3 Ryobi P516 Top Case Replacement: paso 2, imagen 3 de 3
    • Remove the two 10mm T20 Torx screws from the front of the saw.
    • Pull out the front plate.
  3. Ryobi P516 Top Case Replacement: paso 3, imagen 1 de 3 Ryobi P516 Top Case Replacement: paso 3, imagen 2 de 3 Ryobi P516 Top Case Replacement: paso 3, imagen 3 de 3
    • Start at the middle of the device and begin to pry up the rubber grip.
    • Pull the rubber portion inside out towards the front of the saw.
  4. Ryobi P516 Top Case Replacement: paso 4, imagen 1 de 1
    • Remove all twelve 14mm T20 Torx screws from the main case of the device.
  5. Ryobi P516 Top Case Replacement: paso 5, imagen 1 de 3 Ryobi P516 Top Case Replacement: paso 5, imagen 2 de 3 Ryobi P516 Top Case Replacement: paso 5, imagen 3 de 3
    • Remove the four 35mm Phillips #2 screws.
    • Pry the two case halves apart starting at the middle of the saw.
    • Watch out for any loose parts from inside the saw that may fall out during this step.
  6. Ryobi P516 Top Case Replacement: paso 6, imagen 1 de 1
    • Continue splitting the case until the top piece of the case is free and set it aside.
Conclusión
6 personas más completaron esta guía.
2 comentarios
P516 blade locking parts
Bill clark - Contestar
P516 blade locking parts breakdown, please ?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 12
Ultimos 30 días: 78
Todo El Tiempo: 4,325
