Saltar al contenido principal
Ryobi P501G Trigger Replacement
Qué necesitas
  1. Ryobi P501G Trigger Replacement, Shell: paso 1, imagen 1 de 3 Ryobi P501G Trigger Replacement, Shell: paso 1, imagen 2 de 3 Ryobi P501G Trigger Replacement, Shell: paso 1, imagen 3 de 3
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  2. Ryobi P501G Trigger Replacement: paso 2, imagen 1 de 3 Ryobi P501G Trigger Replacement: paso 2, imagen 2 de 3 Ryobi P501G Trigger Replacement: paso 2, imagen 3 de 3
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
  3. Ryobi P501G Trigger Replacement, Trigger: paso 3, imagen 1 de 1
    • After opening the shell, locate the black plastic trigger on the handle of the device.
  4. Ryobi P501G Trigger Replacement: paso 4, imagen 1 de 1
    • Remove the black wiring and the trigger is free! Reposition it however you'd like or switch it out with a new one.
    • Make sure the trigger is snug and exactly where you want it. A dislodged trigger can be very dangerous in a power saw!
Conclusión
Sophia Arias
Miembro Desde 04/21/19
255 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S1-G2, Maness Spring 2019 Miembro de Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 12
Ultimos 30 días: 23
Todo El Tiempo: 1,642
