Saltar al contenido principal
Ryobi P501G Shell Replacement
Qué necesitas
  1. Ryobi P501G Shell Replacement, Blade: paso 1, imagen 1 de 1
    • Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
  2. Ryobi P501G Shell Replacement: paso 2, imagen 1 de 2 Ryobi P501G Shell Replacement: paso 2, imagen 2 de 2
    • Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
  3. Ryobi P501G Shell Replacement: paso 3, imagen 1 de 3 Ryobi P501G Shell Replacement: paso 3, imagen 2 de 3 Ryobi P501G Shell Replacement: paso 3, imagen 3 de 3
    • Remove the four black screws holding the black bearing and remove the bearing itself.
  4. Ryobi P501G Shell Replacement: paso 4, imagen 1 de 1
    • Once the black bearing is off, remove the transparent cover of the blade.
    • Once the cover is off, remove the blade.
    • Place the new blade with the flat notches lined up with the flat notches on the motor axle.
  5. Ryobi P501G Shell Replacement, Shell: paso 5, imagen 1 de 3 Ryobi P501G Shell Replacement, Shell: paso 5, imagen 2 de 3 Ryobi P501G Shell Replacement, Shell: paso 5, imagen 3 de 3
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  6. Ryobi P501G Shell Replacement: paso 6, imagen 1 de 3 Ryobi P501G Shell Replacement: paso 6, imagen 2 de 3 Ryobi P501G Shell Replacement: paso 6, imagen 3 de 3
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
Conclusión
Eeshan Mishra
Miembro Desde 01/24/19
424 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S1-G2, Maness Spring 2019 Miembro de Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 294
