Saltar al contenido principal
Ryobi P277 Trigger Replacement
Qué necesitas
  1. Ryobi P277 Trigger Replacement, Trigger: paso 1, imagen 1 de 2 Ryobi P277 Trigger Replacement, Trigger: paso 1, imagen 2 de 2
    • Lay the device on its side.
    • Remove eight 5 mm screws using a TR10 Torx screwdriver.
    • Separate the two halves by pulling up on the top half.
    • The two halves are still attached, so use caution when opening the device.
  2. Ryobi P277 Trigger Replacement: paso 2, imagen 1 de 1
    • Use a Phillips head screwdriver to remove this bracket.
  3. Ryobi P277 Trigger Replacement: paso 3, imagen 1 de 1
Conclusión
To reassemble your device, follow these instructions in reverse order. You must use solder to reattach the wires in their correct positions.
Alexander Farbo
Miembro Desde 03/08/23
281 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 86
