Saltar al contenido principal
Ryobi P271 Trigger Replacement
Qué necesitas
  1. Ryobi P271 Trigger Replacement, Battery: paso 1, imagen 1 de 3 Ryobi P271 Trigger Replacement, Battery: paso 1, imagen 2 de 3 Ryobi P271 Trigger Replacement, Battery: paso 1, imagen 3 de 3
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P271 Trigger Replacement, Trigger: paso 2, imagen 1 de 1
    • Remove the screws from the drill's casing to gain access to the interior.
  3. Ryobi P271 Trigger Replacement: paso 3, imagen 1 de 1
    • Lift and remove the casing off of the drill body.
  4. Ryobi P271 Trigger Replacement: paso 4, imagen 1 de 1
    • Carefully lift and remove the battery clip, trigger, motor, and everything connected to the wires and pull straight out of the drill.
  5. Ryobi P271 Trigger Replacement: paso 5, imagen 1 de 1
    • Separate the wiring from the trigger and the motor using a soldering iron and them replace them with a new trigger and motor by soldering the wires back together.
    • Follow this guide for soldering tips.
Conclusión
nathan krehbiel
Miembro Desde 11/05/19
229 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team S2-G6, Barthe Fall 2019 Miembro de UMass Dartmouth, Team S2-G6, Barthe Fall 2019
UMASSD-BARTHE-F19S2G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 503
