Saltar al contenido principal
Ryobi P235 Trigger Replacement
Qué necesitas
  1. Ryobi P235 Trigger Replacement, Battery: paso 1, imagen 1 de 2 Ryobi P235 Trigger Replacement, Battery: paso 1, imagen 2 de 2
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Trigger Replacement: paso 2, imagen 1 de 2 Ryobi P235 Trigger Replacement: paso 2, imagen 2 de 2
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Trigger Replacement, Trigger: paso 3, imagen 1 de 2 Ryobi P235 Trigger Replacement, Trigger: paso 3, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Trigger Replacement: paso 4, imagen 1 de 2 Ryobi P235 Trigger Replacement: paso 4, imagen 2 de 2
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Trigger Replacement: paso 5, imagen 1 de 2 Ryobi P235 Trigger Replacement: paso 5, imagen 2 de 2
    • Open the housing with the data label facing up.
  6. Ryobi P235 Trigger Replacement: paso 6, imagen 1 de 2 Ryobi P235 Trigger Replacement: paso 6, imagen 2 de 2
    • Lift the trigger mechanism and other internal components out of the housing assembly.
  7. Ryobi P235 Trigger Replacement: paso 7, imagen 1 de 3 Ryobi P235 Trigger Replacement: paso 7, imagen 2 de 3 Ryobi P235 Trigger Replacement: paso 7, imagen 3 de 3
    • Use a soldering iron to remove the black and red wires connecting the trigger assembly to the motor.
    • Use the soldering iron to connect the new trigger assembly to the motor.
    • Make sure the red wire connects to the lead with the red mark on it.
Conclusión
To reassemble your device, follow these instructions in reverse order starting at step 6.
2 personas más completaron esta guía.
Paul Sousa
Miembro Desde 10/29/19
805 Reputación
5 Guías creadas
Equipo
Un comentario
Is the trigger what makes this a brushless motor? Is it possible for the trigger to cause the battery to drain down completely overnight?
Netgazer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 1,232
