Saltar al contenido principal
Ryobi P235 Magnetic Tray Replacement
Qué necesitas
  1. Ryobi P235 Magnetic Tray Replacement, Battery: paso 1, imagen 1 de 2 Ryobi P235 Magnetic Tray Replacement, Battery: paso 1, imagen 2 de 2
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Magnetic Tray Replacement: paso 2, imagen 1 de 2 Ryobi P235 Magnetic Tray Replacement: paso 2, imagen 2 de 2
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Magnetic Tray Replacement, Magnetic Tray: paso 3, imagen 1 de 2 Ryobi P235 Magnetic Tray Replacement, Magnetic Tray: paso 3, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Magnetic Tray Replacement: paso 4, imagen 1 de 2 Ryobi P235 Magnetic Tray Replacement: paso 4, imagen 2 de 2
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Magnetic Tray Replacement: paso 5, imagen 1 de 2 Ryobi P235 Magnetic Tray Replacement: paso 5, imagen 2 de 2
    • Open the housing with the data label facing up.
  6. Ryobi P235 Magnetic Tray Replacement: paso 6, imagen 1 de 1
    • Remove the magnetic tray from the device.
Conclusión
Paul Sousa
Miembro Desde 10/29/19
805 Reputación
5 Guías creadas
Equipo
Un comentario
Thanks for sharing, I was actually looking for these steps.
Mark Robert - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 301
