Introducción
The direction of rotation selector may not work for multiple reasons.
- The gray plastic forward/reverse piece may be damaged.
- The toggle piece attached to the switch assembly may be damaged.
The drill has to be disassembled to diagnose the problem from the two possible causes. This guide will help to diagnose and solve both problems.
Qué necesitas
Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
Casi Terminas!
Conclusión
