Saltar al contenido principal
Ryobi P235 Direction of Rotation Selector Replacement
Qué necesitas
  1. Ryobi P235 Direction of Rotation Selector Replacement, Battery: paso 1, imagen 1 de 2 Ryobi P235 Direction of Rotation Selector Replacement, Battery: paso 1, imagen 2 de 2
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Direction of Rotation Selector Replacement: paso 2, imagen 1 de 2 Ryobi P235 Direction of Rotation Selector Replacement: paso 2, imagen 2 de 2
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: paso 3, imagen 1 de 2 Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: paso 3, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Direction of Rotation Selector Replacement: paso 4, imagen 1 de 2 Ryobi P235 Direction of Rotation Selector Replacement: paso 4, imagen 2 de 2
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Direction of Rotation Selector Replacement: paso 5, imagen 1 de 2 Ryobi P235 Direction of Rotation Selector Replacement: paso 5, imagen 2 de 2
    • Open the housing with the data label facing up.
  6. Ryobi P235 Direction of Rotation Selector Replacement: paso 6, imagen 1 de 2 Ryobi P235 Direction of Rotation Selector Replacement: paso 6, imagen 2 de 2
    • Lift the internal components out of the housing.
  7. Ryobi P235 Direction of Rotation Selector Replacement: paso 7, imagen 1 de 2 Ryobi P235 Direction of Rotation Selector Replacement: paso 7, imagen 2 de 2
    • Remove the gray plastic forward/reverse selector.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 16
Todo El Tiempo: 767
