Introducción
Before You Start
For your safety, ensure the Ryobi D620H Hammer Drill is not connected to any power source before you perform any repairs.
It is very important to ensure that the electrical connections are correctly replaced in their designated area for the drill to function properly.
Replacing the motor brushes is a very detail-oriented process. It is crucial to ensure you are paying attention to the positions of each wire. If you mix up even one of the connections, the drill will not function after reassembly! If a cellphone with a camera is accessible to you, it will help to take close-up pictures of the drill before disassembly or you can use a marker to mark the wires to their corresponding connections.
Qué necesitas
All nine 16mm long Torx20 screws (Circled in red).
Turn the screwdriver counterclockwise to loosen the screws.
Remove all nine screws completely.
Remove screws and disconnect the two terminals circled in red on the bottom brush bracket.
Remove the longer black wire that connects to the left side terminal
Remove the shorter white wire connected to the brush that connects to the right side terminal
Remove composite shim under the bracket.
Place the new coil spring on the new bracket.
Slide the motor brush wire into the bracket and connect it to the right-side terminal.
Reconnect the longer white wire on the top brackets left side terminal by firmly and steadily pushing down.
Reconnect the longer black wire on the bottom bracket left side terminal by firmly and steadily pushing down.
Replace the composite shim under the brackets.
Screw both brackets down.
You've successfully replaced the motor brushes on your Ryobi Hammer Drill!
Una persona más ha completado esta guía.
