Saltar al contenido principal
Ryobi D620H Mode Selector Switch Replacement
Qué necesitas
  1. Ryobi D620H Mode Selector Switch Replacement, Right Side Case: paso 1, imagen 1 de 1
    • All nine 16mm long Torx20 screws (Circled in red).
    • Turn the screwdriver counterclockwise to loosen the screws.
    • Remove all nine screws completely.
    • Place in parts tray (Optional)
  2. Ryobi D620H Mode Selector Switch Replacement: paso 2, imagen 1 de 2 Ryobi D620H Mode Selector Switch Replacement: paso 2, imagen 2 de 2
    • Pry the right side of the case off to expose the internal components.
  3. Ryobi D620H Mode Selector Switch Replacement, Mode Selector Switch: paso 3, imagen 1 de 1
    • The mode selector switch (Circled in red) once the right side case is removed.
    • Before disassembling, the mode shift button is visible on the top of the case.
  4. Ryobi D620H Mode Selector Switch Replacement: paso 4, imagen 1 de 3 Ryobi D620H Mode Selector Switch Replacement: paso 4, imagen 2 de 3 Ryobi D620H Mode Selector Switch Replacement: paso 4, imagen 3 de 3
    • Push the mode selector switch up (away from the work surface) to dislodge it.
    • Lift the mode selector switch out of its slot.
Conclusión
To reassemble your device, place the mode shift button in the slot it was removed from at a slight angle and straighten it out as you push it into place.
Congratulations, you have replaced the mode shift button on your Ryobi hammer drill!
Una persona más ha completado esta guía.
Jacob da Ponte
Miembro Desde 10/30/23
469 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 1-2, Petersen Fall 2023 Miembro de UMass Dartmouth, Team 1-2, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 83
