Saltar al contenido principal
Ryobi CSB135L Motor Replacement
Qué necesitas
  1. Ryobi CSB135L Motor Replacement, Motor Housing: paso 1, imagen 1 de 1
    • Remove the three M4.5 x 35mm screws that hold the motor housing to the blade housing using a Phillips screwdriver.
    • Although not required for motor housing removal, the two M4 x 16 mm Phillips head screws must be removed for access to the top of the motor.
  2. Ryobi CSB135L Motor Replacement: paso 2, imagen 1 de 1
    • Remove the three M3.5 x 16 mm screws that hold on the laser cover using a Phillips screwdriver.
    • The wires that power the laser prevent the motor housing from coming off, so the laser must be removed.
  3. Ryobi CSB135L Motor Replacement: paso 3, imagen 1 de 1
    • Pry the motor housing (green plastic) from the blade housing (gray plastic) using a metal spudger or any small pry bar.
  4. Ryobi CSB135L Motor Replacement: paso 4, imagen 1 de 1
    • Fully remove the motor housing and blade cover to expose the motor and laser.
  5. Ryobi CSB135L Motor Replacement, Motor: paso 5, imagen 1 de 1
    • Remove the two M4 x 16 mm screws using a Phillips screwdriver.
  6. Ryobi CSB135L Motor Replacement: paso 6, imagen 1 de 1
    • Rotate the saw completely around to view the bottom of the motor as shown.
    • Remove the two 4.2 x 2.54 x 50 screws using a Phillips screwdriver.
  7. Ryobi CSB135L Motor Replacement: paso 7, imagen 1 de 1
    • Pull out the motor assembly.
  8. Ryobi CSB135L Motor Replacement: paso 8, imagen 1 de 1
    • Follow the wires from the motor to the wire cover and black box and undo the fastening of those wires to finish removing the motor from the saw.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 90
