Saltar al contenido principal
Rubber Watch Battery Replacement
Qué necesitas
  1. Rubber Watch Battery Replacement, Battery: paso 1, imagen 1 de 2 Rubber Watch Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Begin by placing the watch on its backside.
  2. Rubber Watch Battery Replacement: paso 2, imagen 1 de 3 Rubber Watch Battery Replacement: paso 2, imagen 2 de 3 Rubber Watch Battery Replacement: paso 2, imagen 3 de 3
    • Gently pull the top of the watch's back until the cap detaches, in a peeling motion.
    • Pull out the white cap and green chip once it is free.
  3. Rubber Watch Battery Replacement: paso 3, imagen 1 de 1
    • Carefully puncture the plastic casing next to the battery on top of the green chip with the X-Acto knife and stop.
    • Be careful not to insert the X-Acto knife too downward into the battery.
  4. Rubber Watch Battery Replacement: paso 4, imagen 1 de 3 Rubber Watch Battery Replacement: paso 4, imagen 2 de 3 Rubber Watch Battery Replacement: paso 4, imagen 3 de 3
    • Flip the chip around to the front.
    • In a chiseling motion, make an incision on the front side above the battery to cut out a plastic casing.
    • Make sure to hold the knife away from the hands in a safe, stable grip.
    • Remove the cut plastic casing over the battery.
    • The plastic casing should come off like a cap.
  5. Rubber Watch Battery Replacement: paso 5, imagen 1 de 1
    • Gently remove the battery with a spudger or a wooden coffee stick.
    • Using too much force may detach the tab holding the battery and break the watch.
    • Once free, remove the dead battery.
  6. Rubber Watch Battery Replacement: paso 6, imagen 1 de 1
    • Insert the new battery.
    • Place the cut plastic cap casing over the chip and battery.
  7. Rubber Watch Battery Replacement: paso 7, imagen 1 de 3 Rubber Watch Battery Replacement: paso 7, imagen 2 de 3 Rubber Watch Battery Replacement: paso 7, imagen 3 de 3
    • Place the white cap over the green chip.
    • Insert the white cap and green chip into the back of the watch with the spudger or wooden coffee stick.
    • Turn over the watch and check the power.
Linea de Meta
Lee
Miembro Desde 04/28/17
110 Reputación
1 Guía escrita
Equipo
UC Davis, Team S2-G5, Cole Spring 2017 Miembro de UC Davis, Team S2-G5, Cole Spring 2017
UCD-COLE-S17S2G5
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 19
Todo El Tiempo: 765
