Saltar al contenido principal
Royal Heat RS-100 Tip Switch Replacement
Qué necesitas
  1. Royal Heat RS-100 Tip Switch Replacement, Panel: paso 1, imagen 1 de 1
    • Unplug the power cord.
    • Flip the device over so the bottom is facing up.
    • Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
  2. Royal Heat RS-100 Tip Switch Replacement: paso 2, imagen 1 de 3 Royal Heat RS-100 Tip Switch Replacement: paso 2, imagen 2 de 3 Royal Heat RS-100 Tip Switch Replacement: paso 2, imagen 3 de 3
    • Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel.
    • Remove the front panel by pulling them apart. The front panel should come out easily.
  3. Royal Heat RS-100 Tip Switch Replacement: paso 3, imagen 1 de 1
    • Remove the two dial caps from the two switches by lifting them up.
  4. Royal Heat RS-100 Tip Switch Replacement, Switch and Circuit Board Assembly: paso 4, imagen 1 de 1
    • Remove the two 10 mm Phillips screws using a #2 Phillips screw driver. One attaches the gold metal bracket to the heater coil housing and the other attaches the fuse holder to heater coil housing.
  5. Royal Heat RS-100 Tip Switch Replacement: paso 5, imagen 1 de 2 Royal Heat RS-100 Tip Switch Replacement: paso 5, imagen 2 de 2
    • Make note of where you disconnect the wires from so you can properly connect them when re-assembling heater.
    • Unplug the wire that goes from the bottom of the power switch to the heater coils. To unplug pull down on the wire until it breaks free.
  6. Royal Heat RS-100 Tip Switch Replacement: paso 6, imagen 1 de 2 Royal Heat RS-100 Tip Switch Replacement: paso 6, imagen 2 de 2
    • Unplug the wire that goes from the bottom of the power switch to the fuse holder. To unplug the wire, pull the wire away from the fuse holder.
  7. Royal Heat RS-100 Tip Switch Replacement: paso 7, imagen 1 de 1
    • Unplug the wires located on the right side of the heat coil housing. Both plugs will come off together. To unplug the wires, pull down on the wire until it breaks free.
  8. Royal Heat RS-100 Tip Switch Replacement: paso 8, imagen 1 de 2 Royal Heat RS-100 Tip Switch Replacement: paso 8, imagen 2 de 2
    • Grab the Switch and Circuit Board Assembly with one hand and slide it up. You will need to wiggle it to break it loose. While wiggling it, slide it up until it is clear of the plastic rails.
  9. Royal Heat RS-100 Tip Switch Replacement: paso 9, imagen 1 de 2 Royal Heat RS-100 Tip Switch Replacement: paso 9, imagen 2 de 2
    • Unplug the two wires, with blue ends, that go from the Power/Fan switch and from the bottom of the Circuit Board to the fan. To unplug the wires, pull them away from the fan assembly until they break free.
  10. Royal Heat RS-100 Tip Switch Replacement, Tip Switch: paso 10, imagen 1 de 1
    • Flip over switch/ circuit board assembly
  11. Royal Heat RS-100 Tip Switch Replacement: paso 11, imagen 1 de 1
    • Remove solder from the two terminals of the tip switch using the soldering iron.
  12. Royal Heat RS-100 Tip Switch Replacement: paso 12, imagen 1 de 1
    • Remove the tip switch from the circuit board by pulling it away.
Conclusión
Luke Nora
Miembro Desde 10/14/13
216 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-35, Amido Fall 2013 Miembro de Cal Poly, Team 11-35, Amido Fall 2013
CPSU-AMIDO-F13S11G35
Miembros de 4
13 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 749
