Introducción
Check the fuse when the current flow through the power cord, but not through the heater coil.
Qué necesitas
Flip the device over so the bottom is facing up.
Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
Pry one end of the fuse from the bracket until it is separated from the holder.
Remove the fuse by lifting it up.
Casi Terminas!
Conclusión
