Introducción
Replace the fan if the fan is not working. The heater will still work if the fan in broken but it will not allow the device to circulate air.
Qué necesitas
Flip the device over so the bottom is facing up.
Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
Remove the three 10 mm screws that attach the fan to the heating coil assembly using the #2 Phillip Screwdriver.
Una persona más ha completado esta guía.
Un comentario
QUESTION OFF TOPIC>>> sorry but don't know who else to ask..
Anyone know if Royal Heat is still in business maybe under a different name? I cannot find anything on the market today that compares to this little heater/fan. Was given one by elderly relative who said he has used it for 20 years and STILL works wonderfully. Poor fellow confined to a nursing home now and said he doesn't need it.
Thank You
