Introducción
This guide will provide a step-by-step walkthrough on how to replace the power assembly of a Rowenta Focus DW5080. This is useful for troubleshooting a faulty power cord and allowing the iron to have power again. This part should only be replaced if the outlet the cord was plugged into has been checked and works. The light on the iron should not be on and the iron should not be getting warm if this part is damaged.
Prior to beginning this repair, be sure the device is turned off and unplugged.
Qué necesitas
Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
To reassemble your device with new power supply, follow these instructions in reverse order.
2 personas más completaron esta guía.
