Saltar al contenido principal
Rowenta Focus Heating Element and Soleplate Replacement
Qué necesitas
  1. Rowenta Focus Heating Element and Soleplate Replacement, Power Assembly: paso 1, imagen 1 de 2 Rowenta Focus Heating Element and Soleplate Replacement, Power Assembly: paso 1, imagen 2 de 2
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
  2. Rowenta Focus Heating Element and Soleplate Replacement: paso 2, imagen 1 de 3 Rowenta Focus Heating Element and Soleplate Replacement: paso 2, imagen 2 de 3 Rowenta Focus Heating Element and Soleplate Replacement: paso 2, imagen 3 de 3
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
  3. Rowenta Focus Heating Element and Soleplate Replacement: paso 3, imagen 1 de 2 Rowenta Focus Heating Element and Soleplate Replacement: paso 3, imagen 2 de 2
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
  4. Rowenta Focus Heating Element and Soleplate Replacement: paso 4, imagen 1 de 2 Rowenta Focus Heating Element and Soleplate Replacement: paso 4, imagen 2 de 2
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
  5. Rowenta Focus Heating Element and Soleplate Replacement: paso 5, imagen 1 de 3 Rowenta Focus Heating Element and Soleplate Replacement: paso 5, imagen 2 de 3 Rowenta Focus Heating Element and Soleplate Replacement: paso 5, imagen 3 de 3
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
  6. Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: paso 6, imagen 1 de 3 Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: paso 6, imagen 2 de 3 Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: paso 6, imagen 3 de 3
    • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
    • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
    • Lift out the piece.
  7. Rowenta Focus Heating Element and Soleplate Replacement: paso 7, imagen 1 de 3 Rowenta Focus Heating Element and Soleplate Replacement: paso 7, imagen 2 de 3 Rowenta Focus Heating Element and Soleplate Replacement: paso 7, imagen 3 de 3
    • Replace with an identical part by inserting it into the space.
  8. Rowenta Focus Heating Element and Soleplate Replacement, Heating Element/Soleplate: paso 8, imagen 1 de 2 Rowenta Focus Heating Element and Soleplate Replacement, Heating Element/Soleplate: paso 8, imagen 2 de 2
    • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
  9. Rowenta Focus Heating Element and Soleplate Replacement: paso 9, imagen 1 de 2 Rowenta Focus Heating Element and Soleplate Replacement: paso 9, imagen 2 de 2
    • Unhook the clips on the top of the metal piece.
    • Using the metal spudger, remove the metal piece on the tip of the iron.
  10. Rowenta Focus Heating Element and Soleplate Replacement: paso 10, imagen 1 de 2 Rowenta Focus Heating Element and Soleplate Replacement: paso 10, imagen 2 de 2
    • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
  11. Rowenta Focus Heating Element and Soleplate Replacement: paso 11, imagen 1 de 3 Rowenta Focus Heating Element and Soleplate Replacement: paso 11, imagen 2 de 3 Rowenta Focus Heating Element and Soleplate Replacement: paso 11, imagen 3 de 3
    • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
  12. Rowenta Focus Heating Element and Soleplate Replacement: paso 12, imagen 1 de 3 Rowenta Focus Heating Element and Soleplate Replacement: paso 12, imagen 2 de 3 Rowenta Focus Heating Element and Soleplate Replacement: paso 12, imagen 3 de 3
    • Lift the iron up using the handle to completely detach the soleplate.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 35
Ultimos 30 días: 116
Todo El Tiempo: 3,357
