Saltar al contenido principal
Rotary Multi Selector Wheel Removal
Qué necesitas
  1. Rotary Multi Selector Wheel Removal, Back Cover Removal: paso 1, imagen 1 de 3 Rotary Multi Selector Wheel Removal, Back Cover Removal: paso 1, imagen 2 de 3 Rotary Multi Selector Wheel Removal, Back Cover Removal: paso 1, imagen 3 de 3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  2. Rotary Multi Selector Wheel Removal: paso 2, imagen 1 de 1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  3. Rotary Multi Selector Wheel Removal, Detaching Ribbon: paso 3, imagen 1 de 2 Rotary Multi Selector Wheel Removal, Detaching Ribbon: paso 3, imagen 2 de 2
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  4. Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: paso 4, imagen 1 de 3 Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: paso 4, imagen 2 de 3 Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: paso 4, imagen 3 de 3
    • Lift up the metal cover and its button slowly using the tweezers.
Conclusión
Andrew Lau
Miembro Desde 04/18/13
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 8-56, Johann Spring 2013 Miembro de Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 500
