Introducción
This guide explains how to replace the USB cable on the Rosewill NEON M62 mouse. This repair should be done if the cable is visually broken or your computer does not recognize the mouse when plugged into it.
Qué necesitas
Place the mouse so the bottom is facing upwards.
Remove the plastic skates.
Remove the two 5 mm screws with a Phillips #00 screwdriver.
Gently pull the cable toward yourself and around the right side, being careful not to damage the wires.
Una persona más ha completado esta guía.
