Saltar al contenido principal
Rosewill NEON M62 Cable Replacement
Qué necesitas
  1. Rosewill NEON M62 Cable Replacement, Bottom Panel: paso 1, imagen 1 de 1
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Cable Replacement: paso 2, imagen 1 de 1
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Cable Replacement: paso 3, imagen 1 de 2 Rosewill NEON M62 Cable Replacement: paso 3, imagen 2 de 2
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
  4. Rosewill NEON M62 Cable Replacement, Cable: paso 4, imagen 1 de 2 Rosewill NEON M62 Cable Replacement, Cable: paso 4, imagen 2 de 2
    • Gently pull the cable toward yourself and around the right side, being careful not to damage the wires.
  5. Rosewill NEON M62 Cable Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Carefully, using your fingers or tweezers, pull the white connecter up.
    • Do not pull by the wires.
Conclusión
Una persona más ha completado esta guía.
Julian Abraham
Miembro Desde 03/21/23
414 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 82
