Saltar al contenido principal
Rosewill NEON M62 Bottom Panel Replacement
Qué necesitas
  1. Rosewill NEON M62 Bottom Panel Replacement, Bottom Panel: paso 1, imagen 1 de 1
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Bottom Panel Replacement: paso 2, imagen 1 de 1
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Bottom Panel Replacement: paso 3, imagen 1 de 2 Rosewill NEON M62 Bottom Panel Replacement: paso 3, imagen 2 de 2
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
Conclusión
Joshua Alves
Miembro Desde 03/16/23
97 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 128
