Saltar al contenido principal
Roku XD 2050X Remote Battery Terminal Replacement
Qué necesitas
  1. Roku XD 2050X Remote Battery Terminal Replacement, Remote Control Casing: paso 1, imagen 1 de 2 Roku XD 2050X Remote Battery Terminal Replacement, Remote Control Casing: paso 1, imagen 2 de 2
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Remove the battery cover.
    • Remove the two AA batteries.
  2. Roku XD 2050X Remote Battery Terminal Replacement: paso 2, imagen 1 de 2 Roku XD 2050X Remote Battery Terminal Replacement: paso 2, imagen 2 de 2
    • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
    • Gently twist the spudger to separate the top and bottom halves of the remote.
  3. Roku XD 2050X Remote Battery Terminal Replacement: paso 3, imagen 1 de 1
    • Gently use the spudger to pry the circuit board loose.
  4. Roku XD 2050X Remote Battery Terminal Replacement: paso 4, imagen 1 de 1
    • Using either end of the spudger, gently lift and remove the clear keypad backing.
  5. Roku XD 2050X Remote Battery Terminal Replacement: paso 5, imagen 1 de 1
    • Using either end of the spudger, lift and remove the rubber keypad.
  6. Roku XD 2050X Remote Battery Terminal Replacement, Remote Battery Terminal: paso 6, imagen 1 de 1
    • Desolder the contacts for the battery terminals.
    • Remove the battery terminals from the circuit board.
    • For hep with soldering view the ifixit soldering guide.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 1,243
