Saltar al contenido principal
Roku Streaming Stick Macro Button Contacts Replacement
Qué necesitas
  1. Roku Streaming Stick Macro Button Contacts Replacement, Macro Button Contacts: paso 1, imagen 1 de 1
    • Place the remote so that the battery cover is facing upwards.
  2. Roku Streaming Stick Macro Button Contacts Replacement: paso 2, imagen 1 de 1
    • Remove the battery cover to expose the battery compartment.
  3. Roku Streaming Stick Macro Button Contacts Replacement: paso 3, imagen 1 de 1
    • Remove batteries.
  4. Roku Streaming Stick Macro Button Contacts Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the 1.5 mm wide screw.
  5. Roku Streaming Stick Macro Button Contacts Replacement: paso 5, imagen 1 de 2 Roku Streaming Stick Macro Button Contacts Replacement: paso 5, imagen 2 de 2
    • Use a plastic opening tool to gently pry apart the plastic enclosure. Make sure you create a large enough gap before you attempt to separate the two pieces.
  6. Roku Streaming Stick Macro Button Contacts Replacement: paso 6, imagen 1 de 1
    • Gently remove the circuit board or motherboard.
  7. Roku Streaming Stick Macro Button Contacts Replacement: paso 7, imagen 1 de 1
    • First, gently remove the three plastic sheets. Then, remove the button panels from the remote control.
    • Repair the contact sheet as noted on the Button Contact Repair Kit listed above. Otherwise replace with new conductive button contacts.
Conclusión
Feliciano Bandazi
Miembro Desde 04/07/18
145 Reputación
1 Guía escrita
Equipo
IUPUI, Team S2-G2, Wilson Spring 2018 Miembro de IUPUI, Team S2-G2, Wilson Spring 2018
IUPUI-WILSON-S18S2G2
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 38
Todo El Tiempo: 3,206
