Saltar al contenido principal
Roku 4 Remote Control Motherboard Replacement
Qué necesitas
  1. Roku 4 Remote Control Motherboard Replacement, Remote Control Motherboard: paso 1, imagen 1 de 1
    • Place the remote control facing down on the table, so that the buttons are facing downwards.
  2. Roku 4 Remote Control Motherboard Replacement: paso 2, imagen 1 de 2 Roku 4 Remote Control Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the battery compartment cover from the back of the remote by sliding it outwards. This should reveal the batteries.
  3. Roku 4 Remote Control Motherboard Replacement: paso 3, imagen 1 de 2 Roku 4 Remote Control Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the batteries from the battery compartment.
  4. Roku 4 Remote Control Motherboard Replacement: paso 4, imagen 1 de 1
    • Turn the Phillips PH0 screwdriver counterclockwise to carefully remove the 6.9 mm screw located between both battery compartments .
  5. Roku 4 Remote Control Motherboard Replacement: paso 5, imagen 1 de 1
    • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device to create a gap.
    • Prying open the remote is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
    • Once you have created a gap large enough for your fingers to fit between, separate the top cover from the bottom plastic casing by pulling them apart gently.
  6. Roku 4 Remote Control Motherboard Replacement: paso 6, imagen 1 de 3 Roku 4 Remote Control Motherboard Replacement: paso 6, imagen 2 de 3 Roku 4 Remote Control Motherboard Replacement: paso 6, imagen 3 de 3
    • Using your right thumb, lift up on the left side of the motherboard to remove it from the bottom plastic casing.
Conclusión
2 personas más completaron esta guía.
Hank Harrison
Miembro Desde 03/26/17
449 Reputación
3 Guías creadas
Equipo
Baylor, Team S5-G4, Williams Spring 2017 Miembro de Baylor, Team S5-G4, Williams Spring 2017
BU-WILLIAMS-S17S5G4
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 1,625
