Saltar al contenido principal
Roku 3 Remote Control Motherboard Replacement
Qué necesitas
  1. Roku 3 Remote Control Motherboard Replacement, Remote Control Battery: paso 1, imagen 1 de 1
    • Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
  2. Roku 3 Remote Control Motherboard Replacement: paso 2, imagen 1 de 2 Roku 3 Remote Control Motherboard Replacement: paso 2, imagen 2 de 2
    • Press and hold the black tab above the battery compartment.
    • While holding down the tab with your left hand, slide down the battery compartment cover with your right hand to remove it.
  3. Roku 3 Remote Control Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the batteries by placing a finger on one end of the battery and pushing downward while pulling the battery out.
  4. Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: paso 4, imagen 1 de 2 Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: paso 4, imagen 2 de 2
    • Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
  5. Roku 3 Remote Control Motherboard Replacement: paso 5, imagen 1 de 2 Roku 3 Remote Control Motherboard Replacement: paso 5, imagen 2 de 2
    • Gently pry open the remote using the plastic opening tool.
  6. Roku 3 Remote Control Motherboard Replacement: paso 6, imagen 1 de 2 Roku 3 Remote Control Motherboard Replacement: paso 6, imagen 2 de 2
    • The remote buttons, sensors, and motherboard are not attached to anything inside the remote. Take apart the remote with caution to ensure these components do not accidentally fall out.
    • Separate the top and bottom of the remote casing.
    • Gently place each half of the remote onto a table so that the exteriors are face down.
  7. Roku 3 Remote Control Motherboard Replacement: paso 7, imagen 1 de 1
    • Set aside the half of the remote with the buttons.
    • Take the the other half of the remote with one hand and remove the motherboard with your thumb and forefinger of the other hand.
Conclusión
3 personas más completaron esta guía.
Isobelle Espiritu
Miembro Desde 10/06/16
591 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 15-2, Livingston Fall 2016 Miembro de Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
3 Miembros
6 Guías creadas
4 comentarios
Thanks for the tutorial. Any idea where I can buy the motherboard for the Roku 3 remote?
Bret Dennis - Contestar
Where can I buy a Roku 3 remote motherboard replacement?
A. J. Sitarsky - Contestar
Hi, wondered if you had any luck locating a motherboard for the Roku 3? Thanks!
Paul Cacioppo -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 26
Todo El Tiempo: 5,093
