Saltar al contenido principal
Roku 3 A/C Power Port Replacement
Qué necesitas
  1. Roku 3 A/C Power Port Replacement, Motherboard: paso 1, imagen 1 de 1
    • Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
  2. Roku 3 A/C Power Port Replacement: paso 2, imagen 1 de 3 Roku 3 A/C Power Port Replacement: paso 2, imagen 2 de 3 Roku 3 A/C Power Port Replacement: paso 2, imagen 3 de 3
    • Pull back the rubber protection in the top right corner to locate the screw.
    • Repeat with the bottom right corner and bottom left corner.
  3. Roku 3 A/C Power Port Replacement: paso 3, imagen 1 de 1
    • Remove the 9 mm screws from the three corners with a Hex 1.3 Screwdriver.
  4. Roku 3 A/C Power Port Replacement: paso 4, imagen 1 de 2 Roku 3 A/C Power Port Replacement: paso 4, imagen 2 de 2
    • Open the device by gently lifting the bottom half away from the top half of the device.
  5. Roku 3 A/C Power Port Replacement: paso 5, imagen 1 de 1
    • Use your fingers to carefully lift the motherboard from the top half of the device.
  6. Roku 3 A/C Power Port Replacement: paso 6, imagen 1 de 2 Roku 3 A/C Power Port Replacement: paso 6, imagen 2 de 2
    • Pull away the IO shield from the motherboard using your hands.
  7. Roku 3 A/C Power Port Replacement, A/C Power Port: paso 7, imagen 1 de 2 Roku 3 A/C Power Port Replacement, A/C Power Port: paso 7, imagen 2 de 2
    • Turn over the motherboard so the back is face up and almost all large silver components are resting facedown on the table.
    • Orient it such that the backside of the HDMI port is in your upper right corner.
  8. Roku 3 A/C Power Port Replacement: paso 8, imagen 1 de 1
    • Desolder the connections of the A/C Power Port on the motherboard.
    • Remove the port.
    • For more information on soldering, check out iFixit's Soldering Guide.
Conclusión
Una persona más ha completado esta guía.
Andy Hak
Miembro Desde 10/07/16
250 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 15-2, Livingston Fall 2016 Miembro de Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
3 Miembros
6 Guías creadas
Un comentario
What’s the size and name of the actual jack? Where do I get a replacement one?
Bo Northwest Designs of SE - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 2,480
