Saltar al contenido principal
Roku 2 Remote Control Buttons Replacement
Qué necesitas
  1. Roku 2 Remote Control Buttons Replacement, Remote Battery: paso 1, imagen 1 de 1
    • Turn over remote and press down on tab to remove.
  2. Roku 2 Remote Control Buttons Replacement: paso 2, imagen 1 de 1
    • Remove batteries
  3. Roku 2 Remote Control Buttons Replacement: paso 3, imagen 1 de 1
    • Place the new batteries into the remote. Make sure the positive terminal is facing the positive terminal of the slot. Similarly the negative terminal should be touching the negative terminal. If done right the batteries should be facing opposite directions of each other.
    • Insert Roku tab back on to its slot.
  4. Roku 2 Remote Control Buttons Replacement, Remote Control Buttons: paso 4, imagen 1 de 1
    • After removing the batteries, use a #000 Phillips to remove the screw.
  5. Roku 2 Remote Control Buttons Replacement, Pry the remote open: paso 5, imagen 1 de 1
    • Use a plastic opening tool to pry open the remote.
  6. Roku 2 Remote Control Buttons Replacement: paso 6, imagen 1 de 1
    • Continue along the top of the remote to lift it off the remote.
    • Lift the top of the remote off very carefully so that board doesn't fall.
  7. Roku 2 Remote Control Buttons Replacement, Replace the buttons: paso 7, imagen 1 de 1
    • Identify the buttons to be replaced and take them out.
Conclusión
10 personas más completaron esta guía.
Alex Saltos
Miembro Desde 08/27/15
526 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-5, Sullivan Fall 2015 Miembro de USF Tampa, Team 1-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G5
3 Miembros
7 Guías creadas
8 comentarios
Well, hmmm; why is it there is actually no screws in mine nor the ones for others. None in mine and 4 in the ones for volume control over tlc tv's etc??
Junebug - Contestar
I use my mobile to control and I download it at: https://apps.apple.com/us/app/roku-remot...
It's better for me
donor - Contestar
And where exactly do you buy the new buttons ??
bonzo dog - Contestar
And just where exactly do you buy the new buttons??
So I tried every trick to get my remote to work (all the Youtube tricks). Found this, took the remote apart and got it to work with the cover off. New remote coming in two days but I just wanted to say thanks cause now I can watch TV while I wait for my new remote to arrive!!!!!!!!!!! I would not advise using the remote with the cover off, just sayin, but I am lol….
Joe MacRitchie - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 22
Todo El Tiempo: 54,136
