Saltar al contenido principal
Roku 2 Case Replacement
Qué necesitas
  1. Roku 2 Case Replacement, Case: paso 1, imagen 1 de 1
    • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
    • Note: It may take several heats, left for a minute at a time, to loosen the glue.
  2. Roku 2 Case Replacement: paso 2, imagen 1 de 1
    • Gently use the plastic opening tool to pry the rubber pads off.
  3. Roku 2 Case Replacement: paso 3, imagen 1 de 1
    • Use the 000 phillips to remove the screws found under all four of the rubber pads.
  4. Roku 2 Case Replacement: paso 4, imagen 1 de 1
    • Gently remove the under side of the device.
  5. Roku 2 Case Replacement: paso 5, imagen 1 de 1
    • Remove the middle component that is held in place by the top and bottom of the device.
  6. Roku 2 Case Replacement: paso 6, imagen 1 de 1
    • Remove the cover over the A/V ports on the front of the device.
  7. Roku 2 Case Replacement: paso 7, imagen 1 de 1
    • Remove the board from the plastic enclosure and put the board into the replacement enclosure.
Conclusión
Una persona más ha completado esta guía.
Eric Rawls
Miembro Desde 08/24/15
360 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-5, Sullivan Fall 2015 Miembro de USF Tampa, Team 1-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G5
3 Miembros
7 Guías creadas
Un comentario
cause mine get’s hot and it’s slow as !&&*
brian price - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 747
